How Options Are Used Within Expressions
Options are used within expressions, such as in Template Studio or model calculations, to control some behavior within OpenGround.
Options headers can be referenced in Template Studio expressions using the same [Group.Header] syntax as any other header reference.
Similarly, Options headers can be referenced in model calculations in a similar manner using the same [Group.Header] syntax.
Please see these examples of How to Use Options for more information on using Options within expressions.
