All Options Groups will be stored within the Options folder in the Project Explorer.
Within OpenGround Professional, Project Options use a form interface and have a form icon within the Project Explorer. Values can be edited, and any edits can be saved/cancelled using the ribbon buttons.
Location Options use a grid interface within OpenGround Professional and can be edited like any other grid by clicking the Add/Edit Data button within the Grid Tools ribbon.
You can create a new record for any Location where you would like to use an Option.
Currently, it is recommended to edit Options values within OpenGround Professional. They are not yet fully supported within Data Entry Profiles.
