Project Sheets
Explanation
A Project Sheet is created in Template Studio and is a report. It is a header sheet style report, but functions at the project level and can read all data in a project. Project Sheets can be used to create summary reports for your project, including Legends.
Applicable Module
Professional, Template Studio
Process – Professional
Project Sheets are not available in Data Entry.
The Project Sheet tool is available from the Grid Tools section of OpenGround Professional.
In order to generate a project sheet the end user need to select the Project Sheet icon in the ribbon. No boreholes need to be selected in order to generate a project sheet. If no boreholes are selected, a project sheet is generated for all boreholes in the project.
Users can also select boreholes to be used when generating a project sheet. If one location is selected the project sheet generates for this location. If 2 or more locations are selected, the project sheet is generated for the selected locations.
The default project sheet when generating a single project sheet is defined under Manage Templates for a specific Configuration pack.
Like Quick Sections and Site Maps, Project Sheets are not available under Log Report Profiles.
Process – Template Studio Project Sheets
 To create a new Project Sheet in Template Studio, select Create => Project Sheet.
The Template Setup window  appears.
Select Paper size, orientation, grid size and set margins here. Once set, the orientation, and grid size are fixed. Margins can be changed at any time.
Grid areas must be merged to create spaces for sheet features. For Project Sheets only General items are available to be added to the sheet. Sheet features available include:
Label text, data label text, image grid, point symbol, dynamic text, static image, project/office logo, and  legend block.
To save the project sheet click Save. Project Sheets flow the OpenGround save options of local, project, and configuration pack. Once saved at the project level or in a configuration pack, the project sheet is available to end users as applicable.
