FAQ
What is OpenGround Portal?
OpenGround Portal is a comprehensive, web-native gateway for end-to-end geotechnical data management. Far beyond a simple data editing tool, it provides a performant, secure environment that allows you to collect, report, manage, visualize, analyze, and access your ground investigation workflows directly from your browser. It serves as the primary web interface to the broader OpenGround cloud-based geotechnical information platform.
What capabilities are available?
OpenGround Portal introduces a broad range of growing, powerful capabilities designed to streamline your entire ground investigation workflow:
Who can have access?
OpenGround Portal access and its features are now fully integrated with the standard OpenGround subscription licenses. Access to it is determined by your organization's existing entitlements. Contact our sales team if you have questions.
How can I access the Portal?
For optimized performance we recommend using the OpenGround Portal tech preview access using the latest Google Chrome or Microsoft Edge browser with the following link: https://portal.openground.bentley.com/
You can also access the Portal by selecting the app in the OpenGround Launcher.
Will I get customer support?
Yes. As a fully released and licensed product, OpenGround Portal is backed by our standard Bentley Technical Support team.
We have added some basic How-To's and Shortcut Keys Section for you to get started.
To view the latest platform enhancements and fixes, check out the refer to the Release Notes.
