OPEN GROUND ADMINISTRATION
Add users to your OpenGround environment, assign the right access, and manage their account details.
OpenGround user and access guides Current article: Create and manage users
| Get ready | Bentley account prerequisites |
| Create users | Create and manage users |
| Access overview | OpenGround access: quick overview |
| Understand access | Access Levels & Roles |
| Assign access | System administrator · System-level access · Project access |
| Protect projects | Manage confidential projects |
Before you begin: You need user-management permissions to see these options. For a guided walkthrough, watch the user management video.
Before you create an OpenGround user, confirm the person has a Bentley account. Use the same email address as their Bentley account so their identity and entitlements can be matched. Open System and select Users to manage accounts in your environment.
If the user belongs to more than one OpenGround environment, remind them to select the correct cloud in Launcher or the application when signing in.
OpenGround includes common groups that can be customized. Choose access according to the work the user needs to perform, and follow your organization's permission policy.
License requirements and group configuration can vary by organization. Confirm the appropriate entitlement and permissions with your OpenGround or licensing administrator. For a walkthrough of user and role setup, see the OpenGround SIG recording.
When creating a user, you can choose to send an automated welcome email with access information. You can also send welcome emails later from User Management.
After creation, review users in the User Management grid. Use the available actions to update accounts, manage administrators, and control access.
| Create/Add User | Create a user account in the environment. |
| Edit User | Update a user's account information. |
| Manage Admins | Assign system administrator access. |
| System Access | Assign access groups that apply at the system level. |
| User Access | Assign or review the user's access for individual projects. Use this for existing projects that are not affected by default groups. |
| CSV Export | Export user information included in the system. |
| Manage Columns | Choose which user information fields appear in the grid. |
| Welcome Emails | Send access instructions to OpenGround users. |
Access check: Default security groups are for new projects. For a user who needs access to an existing project, open User Access and assign the appropriate project-level access.
