PROJECT ACCESS PROCEDURE
Assign projects to users, assign users to projects, and understand how default groups affect new projects.
OpenGround user and access guides Current article: Manage Project Access
| Get ready | Bentley account prerequisites |
| Create users | Create and manage users |
| Access overview | OpenGround access: quick overview |
| Understand access | Access Levels & Roles |
| Assign access | System administrator · System-level access · Project access |
| Protect projects | Manage confidential projects |
Choose the workflow that matches the task. User Access starts from a user and assigns projects to that user. Project Access starts from a project and assigns users to it.
In the Manage Users view, select the user and open User Access. Review their current project access, then assign the required project and security group.
In the Projects List view, select the project and open Project Access. Review who currently has access, then add the users and groups required for that project.
Default security groups are selected when creating a user. They apply when projects are created after the user is added; they do not change access on projects that already exist. Use User Access or Project Access to assign access to an existing project.
Remember: Adding a user does not automatically grant that user access to existing projects.
For permission scope and role precedence, see Access Levels & Roles. To restrict access on a sensitive project, see Manage Confidential Projects.
