Batch Import - Table of Contents
This video will introduce the Batch Import Tool and explain how it can be used to perform a phased migration of your gINT archive.
Additional Notes
- Data migration is an advanced task. You should ideally be very comfortable with both OpenGround and gINT before attempting.
- There is no one-size-fits-all process for a data migration. You may need to adapt the tools and approaches shown within the video examples to fit your organization's requirements.
- Data migration should ideally be performed once OpenGround is embedded within your organization, and you have a stable configuration that meets your project requirements.
- The Batch Import Tool is currently only available to System Administrators.
