This article contains Download links and Change Logs for current and legacy standard Configuration Packs.
For more information on the Version and Key Names, please see this article.
Configuration Pack Guides can be found here.
Individual Components, such as example templates, can be downloaded here.
| Configuration Pack | Guide | Version |
| Australia | Australia | AUS_04.01 |
| North America Metric | North American Metric | NAM_04.01 |
| UK | United Kingdom | UK_04.01 |
| US | United States | US_04.01 |
| Lab | Lab Guide | LAB |
Looking to update an existing configuration pack? If you are an established OpenGround user with a customised configuration, then it may be better to contact our Support team about upgrading your existing configuration pack(s). They can provide a free service to import customisations from your existing configuration pack into one of the newer versions listed on this page. To take advantage of this service, please open a Support Case here.
| Version | Key Name | Change Log |
| AUS_04.01 | Australia |
Added additional headers to the data model for various lab and in-situ testing properties. Added pci (pounds per cubic inch) unit. |
| AUS_03.02 | Australia |
Updated templates to use True Font Sizes. Removed column footer borders in Strip templates to clean up appearance when footer is used as 'overflow area' when scale being used doesn't fit precisely in the depth area. Updated Design>Depth Columns>Split Item Placement property to be 'Last page only' for Strip templates to work better with Dynamic Logs. Enabled the HideOutsideTransition property within applicable template studio objects to work better with Dynamic Logs. Updated many Strip templates to use Range Data Text/Point Data Text along with Boundary Lines in order to work better with Dynamic Logs and for thin layers. Updated many Strip template text objects to use vertical Top Alignment. Updated Test Schedule Type picklist values. Removed "Simple-" prefix from StratumDetails - ColorCode picklist values. Updated expressions in "Strip - Sample and Field Tests - Aus" to better handle blank results. Added Origin to "Strip - Structure and Other Observations - Aus". Set up Installation Well Cap / Pipe Cover graphics in "Strip - Monitoring Installation - Aus"." Added Smart Pointers & Callouts to "Strip - Monitoring Installation - Aus". Added Strip - RQD - SCR - Aus. Made some adjustments and fixes to CPT Log Strips. Added Unit Per Page expression to the CPT Master Template to fit all data on a single page. Added a field for Client on default templates and made other tweaks to better standardize templates. Updated to use Cored & Non-Cored Dynamic Log as default template. Added new Quick Section templates, Quick Section Strip templates, and added Strip Profiles. Redid Site Plan - A4 Landscape - Aus template. Added North Arrow to Site Plan template. Enabled Depth Linking for Geology1 & Geology2 groups. Fixed HideIf expression for Soil Parent Rock in Data Collector Profile. Added Description calculations to Data Collector forms. Removed Termination Reason from Location Details step in Data Collector Profile. Minor tweaks to Discontinuity step in Data Collector Profile. Updated Actions for soil properties to default the Confidence from the previous step. Re-organized Data Collector Display Groups and allocated all Steps to Display Groups. |
| AUS_03.01 | Australia |
Updated data model and mappings to support AGS 4.2. Updated and expanded the CPT data model. Miscellaneous data model and import/export mapping tweaks and fixes. Made Geology1/2 groups part of the standard core model (instead of custom groups). Fixed "Accredition" spelling error in header display names. Added Lab Publish Mapping. Added an example gINT mapping file. Added missing Legend Code images for 419 & CI-CH. Added new image for CL Legend Code. |
| AUS_02.01 | Australia |
Added import/export support for AGS 4.1.1 AU 1.2. Updated standard data model to reflect: Updated mapping files and other components to reflect changes in the data model. |
| AUS_01.04 | Australia |
Repaired Grid View filters. |
| AUS_01.03 | Australia |
This version has been removed after an issue was found within the download file. (Grid View filters did not export.) Added Charts Point Symbols. |
| AUS_01.02 | Australia |
This version has been removed after an issue was found within the download file. (Grid View filters did not export.) Added WSTK2 & WSTK3 Point Symbols. Added NorthArrow Template Image. (Most updates for this iteration were made within the US and North America Metric config packs.) |
| AUS_01.01 | Australia | First version after introduction of version numbering. |
| - | Oceania | Versions prior to introduction of version numbering. |
| NAM_04.01 | North America Metric |
Updated model calculations and data entry conventions for paired text/numeric headers (which originate from AGS 'XN' headings) in order to better align with DIGGS. Updated Data Entry & Data Collector Profiles, CSV & AGS import mappings, and other components accordingly. Added additional headers to the data model for various lab and in-situ testing properties to support additional DIGGS elements. Added a calculated SamplingActivity.Category header. Updated Data Collector profile so there's a single Sampling Activity Step, with the new Category header used to control which fields are visible. Changed SoakawayDepth.DepthWater to Decimal/numeric data type. Removed the Blows Picklist headers from Sampling Activity with the intention that headers for Self Weight Penetration are used instead in order to better align with DIGGS and local standards. Deleted extraneous values from the Field Qualifiers picklist. Added pci (pounds per cubic inch) unit. Updated CSV import mappings to map from groups/headers in legacy configs that have been deprecated/modified. Updated Project Sheets to use SampleInformation.DepthBaseCalculated. |
| NAM_03.02 | North America Metric |
Updated Test Schedule Type picklist values. Fixed an issue with the Plasticity Index calculation expression. Fixed an issue with the Legend on the "Quick Section - Ledger - NAM" template. Updated Chart Group Limit for SPT vs. Depth and MC vs. Depth Project Sheets. Deleted Legacy Quick Section templates from config pack. Slightly renamed Quick Section templates. Added Unit Aliases for DIGGS units. |
| NAM_03.01 | North America Metric |
Updated data model and mappings to support AGS 4.2. Updated and expanded the CPT data model. Updated data model to further optimize for DIGGS support and North America industry practices. Notable changes include: Miscellaneous data model and import/export mapping tweaks and fixes. Fixed "Accredition" spelling error in header display names. Added Lab Publish Mapping. Added an example gINT mapping file. Moved commonly-used groups to the main Summary folder in the Project Explorer. Added new "Nested" Data Entry Profiles for lab data entry in OpenGround Portal. Removed support for AGS 3.1 and AGS 4 NZ import/export. Updated Density - SampleCondition Picklist Values to align with ASTM Density test in Lab Config Pack. |
| NAM_02.01.01 | North America Metric |
Fixed an issue where Project Sheet - Lab Summary - US wouldn't generate due to references to renamed D# headers. |
| NAM_02.01 | North America Metric |
| NAM_01.04 | North America Metric |
| NAM_01.03 | North America Metric |
This version has been removed after an issue was found within the download file. (Grid View filters did not export.) Updated Grid Interval and Axis Tick expressions on Quick Sections to better handle deep and long sections. Added Charts Point Symbols. Added several Chart template examples (lab reports). Updated Description expression on Lab Summary template. |
| NAM_01.02 | North America Metric |
This version has been removed after an issue was found within the download file. (Grid View filters did not export.) Made separate Steps for Non-Component, Soil Component & Rock Component Descriptions in Data Entry Profiles. Moved "Lab Sample Information" Step to end of Logging Data Entry Profiles and made miscellaneous adjustments to help distinguish logging of "Sampling Activities" vs. "Lab Samples". De-activated "Lab Index & Strength Test Data" Data Entry Profile. (Lab Data Entry is currently easiest to enter in Portal Project Explorer). Removed Recovery from Sample Information grids (Data Entry & Explorer) with the intention that Recovery information should be entered in the "Sampling Activity" Groups. For simplification purposes, changed the standard Strip Sets to use "Strip - Sampling Activity Type and Number". Also removed Sample Information from this Strip. Removed Sample Information from the Sampling Activity column in "Strip - Sampling Activity Type and Sample Number". Similarly, removed Sample Information from the "Strip - Recovery RQD" template. Deleted a few of the Sample Strip variations for simplification purposes. Removed Sample Information Recovery headers from Data Collector profile. De-activated additional Groups to help streamline the Project Explorer. Updated SPT Reported Result model calculation to better handle tests ended with blows at 150 or 300-mm penetration and no advancement. Added Project Options and Location Options to control the Units Per Page for the Default and CPT Master Templates. Updated Strips to use PointDataText, RangeDataText, and BoundaryLines. Replaced StraightLine objects for FinalDepth within Strips with BoundaryLines. Updated templates to use True Font Sizes. Removed column footer borders in Strip templates to clean up appearance when footer is used as 'overflow area' when scale being used doesn't fit precisely in the depth area. Made some adjustments and fixes to CPT Log Strips. Deleted "Strip - Lab Results Concatenated" and "Strip - Tests and Remarks". Replaced these with "Strip - Lab Tests" and "Strip - Field Tests and Remarks". (This keeps data related to Samples in one strip and data not directly related to Samples in another Strip, which works better in some scenarios, such as using Boundary Lines.) Deleted "Strip - Fines Content w PSD Data Lookup" and incorporated lookup behavior into "Strip - Fines Content" Deleted "Strip - Graphic Log - Legend Code w Color Code" and updated Strip Sets & "Strip - Graphic Log - Legend Code" accordingly (a separate Strip is no longer needed to color code graphics). Removed "Simple-" prefix from StratumDetails - ColorCode picklist values. Fixed header font size for Torvane strip. Added "Project Sheet - Key To Symbols" template. Added calculated "Type Reported" headers in SPT and Coring groups. These return a default Type if a Type isn't entered. This makes it so that symbols appear in Legend Blocks. Updated Sampling Activity strips accordingly to reference the Type Reported headers. Added "SPT" to SPT test type picklist. Added an example Lab Summary Project Sheet. Added Quick Section Strip Profiles. Added a custom Remarks header to the SectionDetails group. Added a custom SoilBehaviorType header to the StaticConePenetrationData group. Removed previous Quick Section templates and replaced with 1 Legacy Quick Section Template and 2 new Quick Section templates (Letter & Ledger paper sizes). Modified Quick Section Strips. Updated "Strip - Well Installation Details" to only shown Pipe Height/Elevation on first page and to use aggregation to report for multiple installations. Changed Bar Chart Grid Lines style on "Strip - Dynamic Probe Blows" and added line at hole depth. Deleted Dynamic Probe Torque Strip. Added a "z_StripReview - ANSI-D Landscape" template intended for reviewing all Strips available within the config pack. Incorporated this template into the "Template Format Review" Report Profile. Removed extraneous Filter Groups from Well Strips. Updated Well Strips to use Smart Pointers and Callouts. Removed Well Strips from Geotech Strip Sets. Changed some Backfill Legend Code images. Added WSTK2 & WSTK3 Point Symbols. Added Pipe Cover to Well-Installation Data Entry Grid. Added NorthArrow Template Image. Added North Arrow to Site Plan template. |
| NAM_01.01 | North America Metric | First version after introduction of version numbering. |
| - | North America | Versions prior to introduction of version numbering. |
| UK_04.01 | UK |
| UK_03.02 | UK |
Updated Test Schedule Type picklist values. |
| UK_03.01 | UK |
Updated data model and mappings to support AGS 4.2. Updated and expanded the CPT data model. Miscellaneous data model and import/export mapping tweaks and fixes. Fixed "Accredition" spelling error in header display names. Added Lab Publish Mapping. Added an example gINT mapping file. |
| UK_02.01 | UK |
Updated standard data model to reflect: Updated mapping files and other components to reflect changes in the data model. Fixed an issue with Civil 3D template references. |
| UK_01.04 | UK |
| UK_01.03 | UK |
| UK_01.02 | UK |
| UK_01.01 | UK | First version after introduction of version numbering. |
| - | Great Britain | Versions prior to introduction of version numbering. |
| US_04.01 | US |
| US_03.02 | US |
Updated Test Schedule Type picklist values. Fixed an issue with the SamplingActivity.ReportedResult model calculation expression where refusals would get reported with 2 double quotes (inch symbols). Fixed an issue with the Plasticity Index calculation expression. Updated Chart Group Limit for SPT vs. Depth and MC vs. Depth Project Sheets. Deleted Legacy Quick Section templates from config pack. Slightly renamed Quick Section templates. Added Unit Aliases for DIGGS units. |
| US_03.01 | US |
| US_02.01.01 | US |
| US_02.01 | US |
| US_01.04 | US |
| US_01.03 | US |
This version has been removed after an issue was found within the download file. (Grid View filters did not export.) Updated Grid Interval and Axis Tick expressions on Quick Section Templates to use 1-inch intervals with Imperial scales. Updated Quick Section Templates to use Imperial scales. Added Charts Point Symbols. Added several Chart template examples (lab reports). Updated Description expression on Lab Summary template. |
| US_01.02 | US |
This version has been removed after an issue was found within the download file. (Grid View filters did not export.) Made separate Steps for Non-Component, Soil Component & Rock Component Descriptions in Data Entry Profiles. Moved "Lab Sample Information" Step to end of Logging Data Entry Profiles and made miscellaneous adjustments to help distinguish logging of "Sampling Activities" vs. "Lab Samples". De-activated "Lab Index & Strength Test Data" Data Entry Profile. (Lab Data Entry is currently easiest to enter in Portal Project Explorer). Removed Recovery from Sample Information grids (Data Entry & Explorer) with the intention that Recovery information should be entered in the "Sampling Activity" Groups. For simplification purposes, changed the standard Strip Sets to use "Strip - Sampling Activity Type and Number". Also removed Sample Information from this Strip. Removed Sample Information from the Sampling Activity column in "Strip - Sampling Activity Type and Sample Number". Similarly, removed Sample Information from the "Strip - Recovery RQD" template. Deleted a few of the Sample Strip variations for simplification purposes. Removed Sample Information Recovery headers from Data Collector profile. De-activated additional Groups to help streamline the Project Explorer. Updated SPT Reported Result model calculation to better handle tests ended with blows at 6 or 12-mm penetration and no advancement. Added Project Options and Location Options to control the Units Per Page for the Default and CPT Master Templates. Updated Strips to use PointDataText, RangeDataText, and BoundaryLines. Replaced StraightLine objects for FinalDepth within Strips with BoundaryLines. Updated templates to use True Font Sizes. Removed column footer borders in Strip templates to clean up appearance when footer is used as 'overflow area' when scale being used doesn't fit precisely in the depth area. Made some adjustments and fixes to CPT Log Strips. Deleted "Strip - Lab Results Concatenated" and "Strip - Tests and Remarks". Replaced these with "Strip - Lab Tests" and "Strip - Field Tests and Remarks". (This keeps data related to Samples in one strip and data not directly related to Samples in another Strip, which works better in some scenarios, such as using Boundary Lines.) Deleted "Strip - Fines Content w PSD Data Lookup" and incorporated lookup behavior into "Strip - Fines Content" Deleted "Strip - Graphic Log - Legend Code w Color Code" and updated Strip Sets & "Strip - Graphic Log - Legend Code" accordingly (a separate Strip is no longer needed to color code graphics). Removed "Simple-" prefix from StratumDetails - ColorCode picklist values. Fixed header font size for Torvane strip. Added "Project Sheet - Key To Symbols" template. Added calculated "Type Reported" headers in SPT and Coring groups. These return a default Type if a Type isn't entered. This makes it so that symbols appear in Legend Blocks. Updated Sampling Activity strips accordingly to reference the Type Reported headers. Added "SPT" to SPT test type picklist. Added an example Lab Summary Project Sheet. Added Quick Section Strip Profiles. Added a custom Remarks header to the SectionDetails group. Added a custom SoilBehaviorType header to the StaticConePenetrationData group. Removed previous Quick Section templates and replaced with 1 Legacy Quick Section Template and 2 new Quick Section templates (Letter & Ledger paper sizes). Modified Quick Section Strips. Updated "Strip - Well Installation Details" to only shown Pipe Height/Elevation on first page and to use aggregation to report for multiple installations. Changed Bar Chart Grid Lines style on "Strip - Dynamic Probe Blows" and added line at hole depth. Deleted Dynamic Probe Torque Strip. Added a "z_StripReview - ANSI-D Landscape" template intended for reviewing all Strips available within the config pack. Incorporated this template into the "Template Format Review" Report Profile. Removed extraneous Filter Groups from Well Strips. Updated Well Strips to use Smart Pointers and Callouts. Removed Well Strips from Geotech Strip Sets. Changed some Backfill Legend Code images. Added WSTK2 & WSTK3 Point Symbols. Added Pipe Cover to Well-Installation Data Entry Grid. Added NorthArrow Template Image. Added North Arrow to Site Plan template. |
| US_01.01 | US | First version after introduction of version numbering. |
| - | US | Versions prior to introduction of version numbering. |
| Configuration Pack | Key Name |
| ASTM I - American Default | ASTM I - American Default |
| ASTM M - American Metric | ASTM M - American Metric |
| Australian Default | AUS - Australian Default |
| British Standard | British Standard - Default |
