The below information will take you through the updates that are specific to this application. For more general information and product update videos, please see the general New Release page.
1.1.0.4272328
Released 22nd January 2026
- Fixed a bug where it was not possible to add new headers to a step.
1.1.0.4272328
Released 4th September 2025
1.1.0.3678124
Released 2nd June 2025
1.1.0.3576940
Released 6th February 2025
1.1.0.3375938
Released 15th November 2024
1.1.0.3121397
Released 22nd August 2024
- Added additional unit support on step headers to support secondary units for data entry
1.1.0.3033217
Released 18th July 2024
- Added functionality to add more steps in the action create step
1.1.0.2559844
Released 14th December 2023
- Fixed a bug with grid order on steps being inconsistent.
1.1.0.2557195
Released 6th December 2023
1.1.0.2395886
Released 13th September 2023
- Updated logging for the Admin Portal
1.1.0.2372252
Released 6th September 2023
- Bug fix to show a message when a user is trying to open a cloud where the user is not active in.
1.1.0.2367336
Released 31st August 2023
- Fixed a bug where headers that had the Grid Option unchecked were displayed in the summary grid
1.1.0.2355077
Released 29th August 2023
- Added action to add step to end shift
1.1.0.2288051
Released 24th July 2023
1.1.0.2206513
Released 12th June 2023
- Bug fix with concurrent access where user would be prevented from accessing portal if cloud changed multiple times and inactivity logout occurred
1.1.0.2153000
Released 1st June 2023
- Updated to add additional banner text
1.1.0.2008819
Released 14th March 2023
- Fixed a bug with sign out where pressing back on the browser would show data even though user is logged out
- Fixed a security issue showing nginx number on 403 forbidden page
1.1.0.1848162
Released 9th January 2023
- Displaying a banner to access US government clouds
- Prompt user re-authentication after period of inactivity
- Ability to copy mobile data entry profiles
1.1.0.1823321
Released 8th December 2022
New features support Data Collector 3.4 app release
- Added ability to copy an existing profile. New button added to ribbon
- Added ability to customise shift steps. New button added to ribbon
- Added option to attach log on profile sync when creating or editing a new profile
1.1.0.1754531
Released 8th November 2022
- FEDRAMP compliance application shut down logging
1.1.0.1736627
Released 26th October 2022
- Added functionality to enable inactive use timeout of the web page. This is a FedRAMP requirement
1.1.0.1644341
Released 1st September 2022
- FedRAMP compliance for hardened containers
- Added ability to clear a previously applied picklist set to a profile. Selection option is called "not set
1.1.0.1450635
Released 19th May 2022
- Support for Shift Enabled Profiles
- Added new columns:
- Shift enabled
- Log Template
- Strip Set
- Can now assign the desired log template and/or strip set required for a specific profile instead of pulling the profile from Professional
1.1.0.1411628
Released 20th April 2022
- A total location count has been added which is displayed in the top right of the admin portal next to user name. Please note due to the way the query is cached location count is not updated real time but every 24 hours. This means that if locations are added/removed they will not be reflected in the count for 24 hours.
1.1.0.1268730
Released 31st January 2022
- Fixed a bug where if sub steps were reordred they would be removed from the sub steps section and show as a main step effectively no longer being a child.
v1.1.0.1004002
Released 9th August 2021
- Updated Admin Portal to support migration to Azure Cloud infrastructure
v1.0.0.391
Released 22nd February 2021
- Fixed a bug preventing more than 20 steps from being shown on the created profile
v1.0.0.389
Released 02nd February 2021
- Added new configure location step component.
- This new feature is an additional customisable form for configuring the fields to appear when adding/editing locations for the Data Collector App.
- It appears on the mobile data entry tab next to edit profile and is seperate from the rest of the step creation and management process
