Report Grids
The Report Grids within OpenGround Cloud Professionalhave been designed to generate read only data grids that summarise or combine data from multiple grids as fast as possible. The report grids come in different forms displaying different types of data such as a quick count of the samples or information regarding all data at a certain depth within a hole.
Types of Report Grids
There are three different types of report grids within OpenGround Cloud Professional. These, with description are as follows:
Viewing Report Grids
Report grids can be viewed by expanding the relevant report type and then double clicking on the required report.
The report will be filtered by and filter applied by the project manager and can then be further filtered down by using the tools available from within the grid view.
Importing New Report Grids
New report grids need to be created by Bentley. Custom report grids can be created as part of a services engagement.
