Examples and Use Cases
Please see the left-hand menu for some downloadable examples of mapping files for different gINT Project File structures.
The following examples have been put together to help try and give some context to the expressions in the other articles.
Simple Copy fields from Source to Destination
Do this or that examples
The following will copy the field if it is a value or use the replace command to get rid of the "%" sign.
The following will copy numeric values to one field and text fields to a different field.
Running Expressions while copying Fields
The following will join the date and time values from the source file into a single field in OpenGround
Adding Constants to Rows
The following will add a consistent record to every row that matches the row entry.
Using Row Condition
Mapping one input table to more than one OpenGround table
The following example shows you have you include more than one output tag for each input group.
