Strips
Strips are setup in the same way as a depth related area within a borehole template. Therefore, for more information on how any of the depth related items work, please see the relevant section in the guide.
Strips are used to create the template for the depth related items that appear within Sections and Civils Sections. They can also be used to create Strips / Strip Sets for use within Master Templates.
