AUST Technical Information
Investigation Methods and Associated Parts
Report Type
Field Data
Collector Profile
Data Entry Profiles
Standard Log Report Templates
Header Report TemplateS
Borehole (Soil & Rock)
Dynamic Log – Soil and Rock – Aus
Strip Sets
·         Soil Dynamic
·         Rock Dynamic
Header Sheet – Core Box Photo Report
Test Pit & Dynamic Probe
Master Template – Test Pit Log – AUS
Strip Sets
·         Test Pit with Conditional Dynamic Probe
·         Test Pit Only
Header Sheet – Test Pit Photo Report
Well Installation
Master Template – Drill Hole Log - Aus
Strip Sets
·         Monitoring and Installation
Lab Index Test Data
CPT*
*data entry will require import via CSV or a third-party app connected to OpenGround.
Master Template – CPT Log– AUS
Strip Sets
·         qc, fs, Rf, u1 and u2
Quick Sections
Name in interface
Reported Data
Appendix Link
Legend Code (hatch pattern)
Geology Code
Cone Resistance (qc)
Sleeve Friction (fs)
Well graphic (inc. backfill, pipe details, instrument)
Quick Section – Graphic Log - AUS
Appendix G
Quick Section – Graphic Log w CPT - AUS
Appendix H
Quick Section – Graphic Log w Monitoring Installation - AUS
Appendix I
Data Transfer Mappings
OpenGround has support for importing/exporting data into various formats. The AUS configuration supports the following:
Data Format
Import
Export
CSV
gINT
Requires a custom import mapping file for your organization’s gINT data template/library.
 Requires a custom export mapping file for your organization’s gINT data template/library.
AGS 4.1 AU
AGS 4 NZ
AGS 3.1 RTA
AGS 4.1 (UK)
AGS 4.0.4 (UK)
AGS 3.1 (UK)
Excel Report Templates
The Excel Extension allows users to view and analyze data in Excel, create reports, and use Excel's graphing tools to generate diagrams. The configuration pack comes with the following reports and graphs:
