| Data Set |
The GPJ Files and Mapping Files used for the example data migration. The download includes a folder with the entire unorganized GPJ archive, as well as a folder with the GPJ's organized into final Submissions. |
| Batch Import Helper Library |
Contains gINT Rule Add-ins that can be used to help assess and organize your gINT Project File (GPJ) archive. Like all gINT Rules Samples, the Batch Import Helper library is provided as an example, free of charge and as-is. Bentley Systems makes no claim or warranty as to the accuracy of the example. It is the responsibility of the user to ensure that the code performs as it should. Comments, suggestions, and error reports are appreciated. |
| Configuration Packs |
See here. (The videos used a Configuration Pack similar to US_01.01, as well as the Legacy British Standard configuration pack, which is similar to UK_01.01.) |
