Organizing your gINT Archive
Table of Contents
Before you can use the Batch Import Tool, you will need to organize your gINT Project Files (GPJ's) into "Submissions".
These videos will cover tools and approaches that can be used to assess and organize your GPJ's.
The Data Set used for the examples can be downloaded here.
