How do I Use the Different Depth Image Techniques to Plot Images at Different Sizes?
Depending on how you want to plot the images on your logs, there are different options available. This guide explains the different alignments and modes to help you plot the image in the way that you would like.
Please also see this video guide.
And see this article for guidance on working with downhole imagery like televiewer logs or core sketches.
In these examples, the following image will be used.
Point Image
A point image will essentially fill the column with the image, as wide as it can before it runs out of space. It will then scale the image proportionally vertically to match the horizontal space it has used.
Depending on the Vertical Alignment that is selected, the image will appear around the depth selected.
Range Image
Range images will essentially change the scale of the image (although retain its aspect ratio) depending on the space of the column and the size of the image.
Depending on what options are selected, the image can either be ‘chopped off’ at the top and base depth to only show part of the image, or the image can be scaled to ensure that it fits within a column and the depths, or even allow the image to expand past the boundaries of the columns to ensure that no part of the image is lost.
Note that the Allow Column override option will not function unless the Fit to Height option is also selected.
Range Image, Fit To Height and Allow Column Override– With this selection, the image will be plotted between the top and base depths with the image scaled in width to match this aspect ratio. This means that there could be white space within the column around the sides of the image. Any image that appears past the widths of the column will then be shown, past the boundaries of the column, possibly overriding data in those columns.
