Uploading and Importing
Documents can be uploaded to the project or a specific row of data.
To upload a document to the project section, follow the steps below:
To upload a document to a location or any row of data in any data grid in OpenGround Cloud Professional follow the steps below:
Attached documents can be imported into OpenGround Cloud Professional using the FILE group within AGS 3 or AGS 4.
In order for the documents to be imported alongside the AGS data the files must be stored in the AGS 4 recommended folder structure. This is the same folder structure that OpenGround Cloud 3.1 uses but data created by other applications may be different.
The images below illustrate where files need to be stored for import. The file below belongs to the TP1 File Set and so must be stored in a directory \File\TP1 for import. In the below example the AGS file is stored in "C:\file import example" and so the files in File Set TP1 are stored in "C:\file import example\file\TP1".
