The OpenGround Data Collector allows you to create data entry profiles for tablet devices. It is a vital tool for the onsite engineer or driller.
If you have a problem with the software then please log a support ticket using the Product Support page - please select "OpenGround Data Collector" in the product dropdown list as this will ensure that the ticket gets assigned to the correct team and will speed up your response.
| Release Notes | |
| User Guide |
