Template Studio User Guide
What is OpenGround Template Studio?
Customising your template design allows geotechnical data to be presented in your preferred format.  This might be to aid analysis and review or to maintain your company brand when presenting data to clients.
Template Studio has been designed so that users can pick up its simple design techniques quickly, giving you a shorter learning curve and ensuring you are not reliant on a single member of staff to change your template designs.
How to Use this Guide
This guide is structured to deal with concepts in a logical manner and can be read in sequence. At the start of each section you will find an introduction an overview of the relevant capabilities. From these overviews you can follow the linked articles to review specific items in more detail.
Contents
 Charts
 Working with Templates
 The Interface
 Important Template Setting Information
 Using Template Studio
 Template Setup
 Column Configuration
 Powerful Expressions
 Filter Groups
 Designing Tables
 Depth Related Items
 Designing Header and Footer Areas
Types of Template
Strip Profiles
