Components
OpenGround can be customised using the interface. However pre-defined components allow you to import changes quickly and to share components between projects or configuration packs. There are a variety of components within the system and these are listed and explained below:
Components can be imported into an existing project or distributed to multiple projects through the use of a configuration pack.
