Components can be imported into an individual project, as may be the case if the needs of a particular job are quite unusual or specific. This is the same process as Importing Components at the configuration pack level.
The main difference is the Proect must be open. So first, ensure the project is open and then select the Import Components button.
The Import components dialog will display. Browse for the file (.hbc), containing the components to be imported and click Import.
