If you are looking for set up guides for OpenGround please follow the link below. These guides are designed to help a user start to deliver projects with OpenGround.
The 'Getting Started' videos mentioned below are hosted on the learning management system (LMS) and designed to give users who are brand new to the software an overview of key areas of functionality. In many cases, key workflows will be covered to the extent that some users will simply be able to start using the software to achieve similar goals. They are relatively brief by design, allowing users to gain a reasonable amount of familiarity in a short space of time. This short video describes how to gain access to the LMS and find the relevant material.
Other users may require more depth and so may want to follow up with additional learning pathways. This will typically be the case for those who wish to customize the system. These 'Getting Started' videos can still be helpful to introduce some key terminology.
If you are looking for advanced admins or detailed content please see the Training Guides section of the wiki.
We also have some quick reference guides that can be printed off and used as a quick reference for new users. These can be found here.
