OpenGround API Developer Resources
OpenGround provides a REST API that can be used by developers to interact with the OpenGround platform.
We provide a .net/C# SDK and you can also interact directly with the API using the programming language of your choice.
The API provides capabilities including, but not limited to:
To learn more about the OpenGround API, please refer to the following key resources and the video below:
OpenGround API Development Concepts Video
https://vimeo.com/529425577
