US Technical Information
Investigation Methods and Associated Parts
Field Data
Collector Profile
Desktop Data Entry Profile
Log Report Templates
Header Report Template/s
Dynamic Probe US
Well-Installation
Lab Index &Strength Test Data
Soil & Rock Logging
Test Pit Logging
Geotechnical Borehole
Master Template – Default Letter – NA
Strip Sets
·         Geotech BH Columns
·         Geotech BH Columns 2
·         Geotech BH Plots
Header Sheet – Core Box Photo Report
Environmental Borehole
Strip Sets
·         Enviro BH
Monitoring Well
Strip Sets
·         Well
Test Pit
Strip Sets
·         Test Pits
Header Sheet – Test Pit Photo Report
CPT*
*Data entry will require import via CSV, API or a third-party app connected to OpenGround.
Master Template –  CPT Default Letter – NA
Strip Sets
·         qc, fs, Rf,u1 and u2
Quick Sections
Name in interface
Reported Data
Appendix
Legend Code (hatch pattern)
Cone Resistance (qc)
Sleeve Friction (fs)
Water Levels
SPT N Value
RQD
Well graphic
Quick Section – Graphic Log - US
Appendix E
Quick Section – Graphic Log w CPT - US
Appendix F
Quick Section – Graphic Log w WL – N Value – RQD - US
Appendix G
Quick Section – Graphic Log w WL – Well - US
Appendix H
Data Transfer Mappings
OpenGround has support for importing/exporting data into various formats. The US configuration supports the following:
Data Format
Import
Export
CSV
gINT
Requires a custom import mapping file for your organization’s gINT data template/library.
 Requires a custom export mapping file for your organization’s gINT data template/library.
AGS*
 *The data entry conventions used in the US Configuration Pack may not be compatible with certain aspects of the AGS data formats, and care may need to be taken when exporting or importing from these formats.
Excel Report Templates
The Excel Extension allows users to view and analyze data in Excel, create reports, and use Excel's graphing tools to generate diagrams. The configuration pack comes with the following reports and graphs:
SPT vs Depth and Elevation
