Investigation Method |
Field Data Collector Profile |
Desktop Data Entry Profile |
Log Report Templates |
Header Report TemplateS | |||
Dynamic Probe Data |
Well-Installation |
Lab Index Test Data |
Soil & Rock Logging | ||||
Trial Pit |
Master Template – BS Trial Pit – UK Strip Sets · BS TP | |
Dynamic Probe |
Dynamic Log – BS Template – UK Strip Sets · BS DP |
Pecussion Drilling |
Dynamic Log – BS Template – UK Strip Sets · BS CP |
Header Sheet – BS - UK |
Rotary Core |
Dynamic Log – BS Template – UK Strip Sets · BS RC |
Header Sheet – Core Images - UK |
CPT* |
*Data entry will require import via CSV, API or a third-party app connected to OpenGround. |
Master Template – CPT Log– UK Strip Sets |
Name in interface |
Reported Data |
Appendix Link | ||||
Legend Code (hatch pattern) |
Geology Code |
Cone Resistance (qc) |
Sleeve Friction (fs) |
Well graphic (inc. backfill, pipe details, instrument) | ||
Quick Section – Graphic Log - UK |
Appendix G |
Quick Section – Graphic Log w CPT - UK |
Appendix H |
Quick Section – Graphic Log w Monitoring Installation - UK |
Appendix I |
OpenGround has support for importing/exporting data into various formats. The UK configuration supports the following:
Data Format |
Import |
Export |
CSV |
gINT |
Requires a custom import mapping file for your organization’s gINT data template/library. |
Requires a custom export mapping file for your organization’s gINT data template/library. |
AGS 3.1 |
AGS 4.0 |
X |
AGS 4.0.3 |
X |
AGS 4.0.4 |
AGS 4.1 |
The Excel Extension allows users to view and analyze data in Excel, create reports, and use Excel's graphing tools to generate diagrams. The configuration pack comes with the following reports and graphs:
