The Site Plan Production section of the ribbon allows for the creation of site plan outputs. OpenGround Cloud Professional uses a new graphing component that has been designed from the ground up to quickly and efficiently produce site plans on the fly as and when needed. The Legend Key will also update to include any used datasets or section lines used within the mapping area.
| Generating a Site Plan | |
| Preview and Generate | |
| Site Plan Parameters |
