Using the Data Entry Tool
The Data Entry Tool is the fastest way to type data into OpenGround Cloud Professional and can be accessed by clicking on the Data Entry Tool on the Data Ribbon (as shown below).
When you open the Data Entry Tool the program will ask you to select one of the available data entry profiles from the drop-down list. Each Profile will be set up to enter specific categories of data, such as, cable percussion field data, or laboratory testing.
Each Data Entry Profile is made up of one or more steps and each step can contain one or more data entry grids. The image below shows how the system looks for the second step of the Cable Percussion profile.
Contents
 Navigating Around a Data Entry Profile
 Entering Data into Professional
 Copying Data into Professional
 Editing Data in Professional
 Deleting Data in Professional
 Inserting Multiple Records in Professional
 Previewing Logs in Professional
 Saving and Retrieving Data in Professional
 Boundary Lines on Logs
 Using Control Grids in Professional
 Document Manager in Professional
 Designing Data Entry Profiles
 Shortcut keys in Professional
