Docking Tabs and Resizing
OpenGround Cloud Professional uses a docking and locating system that allows for any interactive part of the application to be moved to a convenient location to allow for easier viewing.
By default, when loading OpenGround CloudProfessional, the screen will show only a list of projects and their details. A map showing a summary of these projects can be enabled by selecting the Open Map option from the ribbon. Once enabled, the screen will be split into two sections. One of these is for the project information and the other is for the mapping. This is an example of the screen being split up into two sections allowing for multiple views of the same data.
It is possible to undock a tab and place it anywhere on the screen. This can be done by clicking on the tab heading and dragging the tab towards the middle of the screen. This is demonstrated in the below screenshot where the project information tab has been dragged into the middle of the screen and the mapping interface has then updated to fill the entire screen behind it.
After undocking a tab, it is then possible to re-dock the tab back into a fixed position on the screen. When moving the tab around the screen, a dock option (shown below) will appear in the middle of the screen. Simply move the tab over the section of the icon that you wish for the tab to be docked to. For example, if the tab is to be docked to the bottom half of the screen, move the tab to the bottom arrow of the icon.
Tabs can be docked in multiple locations, allowing for multiple tabs of information to be on display at any one time. See below example of multiple tabs being viewed at once.
It is also possible to right click on the heading of a tab to see options for where the tab can be docked.
Tabs can also be moved to areas outside of the main OpenGround Cloud Professional window. If using a setup with multiple monitors then it is possible to have a full screen showing mapping on one monitor and another full screen showing data information.
