OpenGround Data Collector supports tracking of shifts to help manage field operations. Shifts are tracked on a per location basis so multiple crews can be working on a site simultaneously. Because shifts are tracked per location, one user may have multiple shifts throughout a work session such as when moving between locations. There can also be multiple shifts active at once if multiple locations are being worked at the same time with additional crews.
Once a shift has been activated, all data entered will be tracked against that shift and allow users and managers to review the work accomplished during a given shift. Logs can be generated per shift, or combing shifts together to generate a complete borehole log at the end of the location.
| Ending a Shift and Viewing Shift Logs | |
| How to Start a New Shift | |
