Sample Templates for getting started with the OpenGround to PowerBI Connector
Cloud Parameters Report | Used to get CloudID Parameters that are used in all other reports. |
Location Counts | Used to demonstrate cross-project queries and provides a summary of total locations (Boreholes). |
Project Geology Summary | Provides a summary of geology and depth ranges in a selected project. |
Project Summary | Alternative method for Project Selection and Summarizing Projects |
Validation Examples | Shows an example of manipulating data to check for errors in project data. |
Lab Summary Report | An advanced example to show how to manipulate data within Power BI |
Blank Template | A template set up to return project data that can be added to for your next report. |
