Dynamic Templates pull together different templates (including borehole logs and master templates) and pulls them together into one consolidated output. This allows for an output to show different data dynamically based on data in the database structure. For example, you could show soil data on one type of template and rock data on another (with different strip sets used as well).
Note that a dynamic log will always ‘start a new page’ when a template type change is detected. This works differently to a combined log which will carry on the new template on the same page as the previous one. There are further settings to show different information in the space where a new page has been created explained further in this guide.
| Dynamic Template Description Bars | |
| Expression and Condition Examples | |
| Setting up a Dynamic Log | |
