This section of the user guide looks at formatting the Header and Footer Areas of a log by working through part of an example.
A blank form with a grid (like a graph paper) is initially shown when a new template is created. This form is divided into three areas:
The size of the grid cells (small, medium, large) has already been set up on the Template Setup Form.
| Label Object | |
| Data Label Text Object | |
| Point Symbol Object | |
| Vertical Scale Object | |
| Dynamic Text | |
| Sheet Counter | |
| Table Objects | |
| Image Grids | |
| Site Plan Legend | |
| Site Plan Plan | |
| Site Plan Scale | |
