There are sub menus to the portal that can be accessed from the Project list screen. Select the Project List tab, this will display the project in a familiar grid format.
If the Project list is large, you are able to filter and paginate using the filter icon over the grid headers and switch pages via the page select buttons.
To make the Project appear in the current list, select the option make current. The project is now in the current project Lists.
If you toggle back to the Current Project list, you will see the Project showing along with a count of each Locations Status. Projects are set as current per user. In other words, different users will see different projects set as current in the Project List.
If you select a status it will display a list of all the locations based on the status type for convenience.
As with the Project grid, the Location grid can filter data also.
