It is possible to set a project to be 'current' using the 'Toggle Current' button in the Grid Tools Ribbon. All projects marked as current will be placed at the top of the Projects grid so that they appear above any projects that are not set as current.
Projects are set as current per user. In other words, different users will see different projects set as current at the top of their Projects grid.
