Column Configuration
The depth related area of templates consists of columns. Columns are placeholders into which object definitions are placed from the library. This section discusses the parameters of these columns (such as their order or width) and their management:
Contents
 Adding Columns
 Adding Sub Columns
 Removing Columns
 Moving Columns
 Continuation Text
 End of Borehole Text
 Column Borders
 Footer Areas
 Distinct Sequential Records
 Grouping and Ordering
 Strip Set Columns
 Section Centre Column
  Hide Column Conditions
What data is displayed within a column and how is determined by the depth related library items.
