To change the column borders, follow the steps below:
- Click the Depth Columns button on the Design section of the ribbon.
- The Depth Column window opens and under the Columns Group select the column name that the borders are going to be changed in.
- Click the Borders button to display the Edit Border form.
- On this form it is possible to specify the colour and type of border in the top half and then the thickness in the bottom half. If no borders are required, then set the style to None. If only one or two of the sides will not have a border, then set the appropriate side to zero thickness.
