The Section Centre Column option allows for the selection of a column to be the central alignment for the whole Strip when used on Quick Section and Civils Section templates.
If used in conjunction with the Hide Column Options (currently only supported for Quick Sections), this column will stay centered as other columns are hidden.
There are 3 different options for Section center column;
Left – This will align the left hand side of the column to be the center of the strip.
Center – This will align the center of the column to be the center of the strip.
Right – This will align the right hand side of the column to be the center of the strip.
