AUST Sample Templates and Pieces
The following pages explain the examples templates and other pieces that are available within the configuration pack.
Contents
 Dynamic Log – Soil and Rock - Aus
 Dynamic Log – Drill Hole Log - Aus
 Master Template – Test Pit Log - Aus
 Master Template – CPT Log – AUS
 Header Sheet – Core Box Photo Report
 Header Sheet – Test Pit Photo Report
 Quick Section – Graphic Log - AUS
 Quick Section – Graphic Log w CPT - AUS
 Quick Section – Graphic Log w Monitoring Installation - AUS
