After selecting a project, the Templates window opens up:
Items on this form are colour-coded:
Select a template and press the Open button.
Templates can be saved to external files to allow them to be distributed. To load such a template file (.hbt) click the Load button and browse to the file:
Note that you will need to save the template manually to store it on the system.
