Format
Select the format of the data to be imported. The choices currently available are Autodesk DXF and ESRI SHP.
DXF
OpenGround Cloud Professionalwill support the import of any DXF file format up to AutoCAD 2014.
SHP
As a minimum, the dataset should include two files with the extensions.SHP,.IDX and the.DBF file (which includes all of the attribute data). If the dataset does not include an associated DBF file, then the labels and tooltips cannot be displayed. All of these files will need to be included in the same directory as the.SHP file.
