Trigger Themes
Once a trigger set has been setup, a theme can then be used to theme the data dependent on the results. Select the Trigger Themes option from within the Create Trigger Set window or from within the Trigger Levels Window to access the theming.
The theming window will then appear, allowing for multiple categories to be setup. Enter all of the required values and set a unique code for each one.
The code option is used to distinguish each value as there may be more than one value with the same description.
Once all of the values have been entered and a unique code selected, colours can then be applied to each category. This can be done by either selecting each category manually and then changing the colour to the required colour, or, multiple options can be selected together to create a cascading colour effect. To do this, select multiple values within the table and select the Colours option.
Select a start colour and an end colour. The program will then create a cascading effect where each value will have a colour starting from the 1st colour, moving down until the bottom colour is reached. For example, if the first colour is red and the end colour is yellow then the middle value would be orange as in the screenshot below.
The themes will then be made available for when entering the trigger values.
