Before purchasing a tablet for OpenGround Collector, please validate the requirements:
Minimum Tablet Requirements:
The most important thing is to make sure both the CPU and the Android version are 64-bit. It is possible for the CPU to be 64-bit while your Android might only be 32-bit and OpenGround Cloud Data Collector will not work with this configuration.
Refer to the documentation for further information on installation.
You must have the following to use OpenGround Data Collector:
1) The Data Collector Software installed on your Tablet. This can be downloaded and installed directly from the Google Play Store
2) A Bentley Login which must be linked to an account with OpenGround Collector Licences available. Your administrator will be able to set this up for you. Full information on how to manage users in your Bentley Connect Portal.
3) Granted access to at least one OpenGround instance (using the same email address as your Bentley Account). Full information on User Management in OpenGround
4) Access to one or more projects on the OpenGround Instance.
