Creating Table Relationships
Tables that OpenGround imports into Power BI are stand-alone and have no knowledge of, or relationship to, the other tables in the report.
This can cause problems when trying to get tables to work together - For example, if you have two tables in a report which have a Location ID column and you use Location ID from one table in a filter Visual, then the filter will only apply to the table you selected the field from and won't filter the other tables.
To define relationships between the tables you need to follow the steps below:-
The majority of relationships that you create in your report will be one-to-many and can be set up using the method above.  However, you can select the line between the tables and right click to edit the relationship using the form shown below
Important Note:
Power BI only allows you to create a relationship using one field from each table.  If you need to join by more than one (for example lab test results linked to samples) then you will need to create a new column in the table and concatenate the fields to create a key field combination column.  How to do this is described in the Create New Column section.
Tables cannot be joined to themselves.  However a duplicate table can be created, and the two tables can be joined.  This technique is used to find non continuous geology.
