This article is outdated. Please see Import/Export Mapping Functions.
Function |
Description |
Example |
CanCreate |
Determines if a specified table has not had its creation restricted by PreventCreation(). |
CanCreate(‘Table’) |
ConcatenateDateTime |
Combines a time and date fields into one date-time value. The time component is added to the date field’s value. |
ConcatenateDateTime('Date Field', 'Time Field') |
ConcatenateFormattedDateTime |
Combines a time and date fields into one date-time value. The time component is added to the date field’s value. Due to the possibility of multiple date and time formats in the incoming data, this will try each date and time format in order with the data until it finds the one it matches. Any number of possible combinations can be added. |
ConcatenateFormattedDateTime('Date Field', 'Time Field', 'M/d/yy,MM/dd/yyyy', 'HHmm,HH:mm')
(In this example it will try and match M/d/yy first, then MM/dd/yyyy second. With the time field, it will try HHmm first, then HH:mm second) |
ExtractDate |
Extracts the date component from a combined date-time value. A string is returned. This function requires that the input value is valid date-time value and could be obtained from the HBSI model during an export process.
Note that the argument is the value itself and not a single-quoted string containing the name of the field. |
ExtractDate(DateTimeField) |
ExtractTime |
Extracts the time component from a combined date-time value. A string is returned. This function requires that the input value is valid date-time value and could be obtained from the HBSI model during an export process.
ExtractTime(DateTimeField) |
GetDeterminand |
Attempts to ascertain the determinand for a known determinand and test type combination. The internal lookup table is fixed as it links AGS 3.1 determinands and test types to the HBSI equivalents. If a match cannot be found, an empty string is returned. |
GetDeterminand(CNMT_TYPE, CNMT_TTYP) |
GetDeterminandReverse |
Reverses the operation of GetDeterminand(). |
GetDeterminandReverse(Determinand, TestType) |
GetEntityValue |
Obtains the raw value of a row given the source table name, field name and its unique identifier within that table. The ‘ID’ must be a GUID. |
GetEntityValue(ID, ‘Table’, ‘Field’) |
GetFieldUnit |
Provides the unit of a field in the HBSI model, if available. |
GetFieldUnit(‘Group’, ‘Field’) |
GetPickListCode |
Returns the value of a picklist from its unique identifier. |
GetPickListCode(ID) |
GetPicklistDescription |
Returns the description of a picklist value associated with a given group’s field. |
GetPicklistDescription(‘Group’,’Field’,’Value’) |
GetTestType |
Attempts to ascertain the test type value for a given determinand and test type combination. The internal lookup table is fixed as it links AGS 3.1 determinands and test types to the HBSI equivalents. If a match cannot be found, an empty string is returned. |
GetTestType(CNMT_TYPE, CNMT_TTYP) |
GetTimestamp |
Adds the time component to a date-time field’s value. The time field can be a date-time value or a string containing a time value in a specific format. The final argument is mandatory if the time field is not a date-time value but optional otherwise. |
GetTimestamp(DateValue, TimeValue) GetTimestamp(DateValue, ’12:00’, ‘HH:mm’) |
GetIsoTimestamp |
Adds the time component to a date-time field’s value. The time field can be a date-time value or a string containing a time value in a specific format. The final argument is mandatory if the time field is not a date-time value but optional otherwise. This is locale independent |
GetIsoTimestamp(DateValue, '0000', 'hhmm') |
GetOfficeName |
Retrieves the name of an office when the raw identifier of the office is known. This identifier may be associated with a project. |
GetOfficeName (OBJECT_ID) |
GetUnit |
Obtains the units associated with a given field. |
GetUnit(‘HOLE_GL’) |
GetYesNoValue |
Converts a Boolean ‘True’ or ‘False’ to ‘Y’ or ‘N’, respectively. |
GetYesNoValue(‘True’) |
IsContainedIn |
Returns true if a value exists in a list of strings. |
IsContainedIn(Field, 'X’, ‘Y’, ‘Z’) |
IsDefined |
Returns true if a field contains a value. Note that the name of the field is required and not the actual value. |
IsDefined(‘Reading’) |
IsLocationValid |
Returns true if the value held in the specified field exists in the set location IDs selected to be imported or exported. |
IsLocationValid(‘LocationId’) |
IsLocationValidByValue |
Returns true if a specified string belongs to the set of location IDs selected to be imported or exported. |
IsLocationValidByValue(‘BH127’) |
IsNumeric |
Returns true if a value is numeric. If the type of provided value is numeric, true will always be returned. If a string is passed, true if returned only if it contains a numeric value. |
IsNumeric(1234.5) IsNumeric(‘1234.5’) IsNumeric(Field) |
IsProjectValid |
Determines if the value of a field for the current input row matches the current project’s ID. |
IsProjectValue(‘Field’) |
IsUndefined |
Returns true if a field does not contain a value. Note that the name of the field is required and not the actual value. |
IsUndefined(‘Reading’) |
IsValueAssumed |
Returns true if the value contains a single hash (‘#’). |
IsValueAssumed(Field) |
LookupSourceValue |
Used to find a value elsewhere in the incoming dataset. |
LookupSourceValue('Table Name', Field Name) |
LookupSourceValueConditional |
Determines the value of a field within an input table where the originating row satisfies a given condition. |
LookupSourceValueConditional(‘Table’,’Condition’, ‘Field’) |
LookupValue |
Used to obtain a value in the destination/output tables. |
LookupValue('Table Name', ‘Condition’ ‘Field Name’)
LookupValue('SampleInformation', 'LocationID = \'' + [PointID] + '\' AND Convert(DepthTop, \'System.Double\') <= ' + fixed(Depth, 3, false) + ' AND Convert(DepthBase, \'System.Double\') > ' + fixed(Depth, 3, false), 'DepthTop')
(The above expression will find the sample information key fields to try and join up lab test data to its parent samples where the sample data has been created from different sources) |
LookupExistingValue |
Used to join children records onto a parent record when they only have part of a parent match. For example, joining lab data onto samples with only the sample reference and none of the other key fields. |
LookupExistingValue('Table Name', 'Field Name', 'Query Field 1', Query Field Value 1, 'Query Field 2', Query Field Value 2)
LookupExistingValue('SampleInformation', 'SampleID', 'LocationDetails.LocationID', [Location ID], 'SampleReference', [Sample Reference]) |
PreventCreation |
Prevents the specified output table from being created for the current input row. Duplicate entries are permitted as only unique names are retained. This function always returns true. |
PreventCreation(‘Table’) |
RemoveAssumedPrefix |
Removes all characters which are not numeric, decimal points (‘.’) or commas (‘,’). |
RemoveAssumedPrefix(Field) |
RemoveTrailingZeroes |
Removes trailing zeroes from the provided string but only if it contains a numeric value. If the removal could not be performed, the provided value will be returned. |
RemoveTrailingZeroes(Field) |
ToDegreesMinutesSeconds |
Converts a decimal coordinate value to the degrees:minutes:seconds format. |
ToDegreesMinutesSeconds(Field) |
