This guide explains how to use OpenGround's custom query functions in Power BI. It is intended for users who need to retrieve OpenGround data for reporting and analysis but may not be familiar with the underlying API or technical implementation details.
The examples in this guide focus on common reporting tasks such as connecting to OpenGround, retrieving project data, filtering results, and troubleshooting common issues.
Before building reports, confirm that you can successfully connect to OpenGround and view available projects.
let
Cloud = OpenGround.GetCloud("BentleyUS", "eastus"),
Projects = OpenGround.GetProjects(Cloud)
in
Projects
A table containing the projects available to your OpenGround account.
Most OpenGround data is stored in related levels. Understanding these relationships makes it easier to build reports.
Project
└─ Location
└─ Sample
└─ Test
For example, a project can contain many locations. Each location can contain many samples, and each sample can contain one or more tests.
| Term | Description |
| Project | An OpenGround project. |
| Group |
A set of data in OpenGround such as Location Details, Sample Information, or Field Geological Information. (ie. a table in OpenGround) |
| Grid |
A predefined subset of Projections (i.e. Columns) from a Group. |
| Projections or Header | An individual item of information such as Location ID or Sample Depth. (May also be referred to as Fields in PowerBI, or Columns in a display sense). |
OpenGround query functions use several common Power Query value types and structures. Understanding these formats will make it easier to build queries and troubleshoot errors.
The formats below are used throughout the examples in this guide.
Format |
Description |
Example |
| Text | Words and Characters, enclosed in double quotation marks. | "This is a text Example" |
| Number | Numeric Values. | 3.14159 |
| List | A collection of values, enclosed in curly brackets { }. | {"A", "B", "C"} or {1, 2, 3} |
| Record | A collection of Named Properties, enclosed by square brackets [ ]. |
| Table | A collection of rows and columns. Most OpenGround query functions return data as a table. | N/A |
| Function | A reusable operation that accepts inputs and returns a result. | OpenGround.QueryProject(...) |
OpenGround provides several query functions. The best choice depends on what data you need and how much control you want over the results.
Use when:
OpenGround.QueryProjectGrid(
Cloud,
ProjectId,
"Sample Information"
This is the recommended starting point for most users.
Use when:
Cloud,
ProjectId,
GroupName,
Projections
Use when retrieving data from multiple projects.
OpenGround.Query(
Cloud,
Projects,
GroupName,
Projections,
Filters,
Groupings,
Orderings
Before building a report, it is often useful to see what projects, grids, and fields are available.
OpenGround.GetProjectGrids(
Cloud,
ProjectId
Using these discovery functions can save time and help avoid typing errors when building reports.
When creating reports, only return the fields you actually need.
Projections = {
"LocationDetails.LocationID",
"LocationDetails.LocationType"
This query returns only the Location ID and Location Type fields.
Groupings allow you to combine rows together and perform calculations such as totals, averages, minimum values, and maximum values.
A Grouping is defined using a collection of records containing a Group, Header, and Aggregate value.
Groupings = {
Group = "",
Header = "",
Aggregate = ""
Groupings = {
Group = "LocationDetails",
Header = "LocationType",
Aggregate = "None"
Group = "SampleInformation",
Header = "DepthBase",
Aggregate = "Avg"
| Aggregate | Description |
None |
Groups rows by the selected field. |
Avg |
Returns the average value for each group. |
Count |
Returns the number of rows in each group. |
Max |
Returns the highest value in each group. |
Min |
Returns the lowest value in each group. |
Sum |
Returns the total value for each group. |
Header Aggregate.Filters allow you to return only the rows that match specific criteria.
A filter is defined using a Group, Header, Operator, and Value.
Filters = {
Group = "",
Header = "",
Operator = "",
Value = ""
Filters = {
Operator = "Equals",
Value = "Geotech BH"
Filters = {
Header = "Remarks",
Value = null
These operators are typically used with text values. Text values should be enclosed in quotation marks.
These operators are used for numeric and date values. Numbers and dates do not need quotation marks.
Orderings control the order in which rows are returned.
An ordering is defined using a Group, Header, and Ascending value.
Orderings = {
Group = "",
Header = "",
Ascending = true
Orderings = {
Header = "LocationID",
Ascending = true
| Value | Description |
true |
Sort in ascending order (A-Z, 0-9). |
false |
Sort in descending order (Z-A, 9-0). |
More than one ordering can be supplied. Orderings are applied in the order they appear in the list.
Orderings = {
Ascending = true
Ascending = true
The example below connects to OpenGround, filters location data, and returns the results.
let
Cloud =
"BentleyUS",
"eastus"
Columns = {
Filters = {
Results =
Cloud,
ProjectId,
"LocationDetails",
Columns,
Filters,
null
in
Results
