In Excel adding new office information to a report is done via the Insert Option. Scroll down to Office Details and select the items to be added to the report.
To add the Project/Office Image select the item from the Insert menu also.
Much like Template Studio existing template images can still be added via the Template Image item in the Insert Drop-down.
When the report is run it will now display the logo and the office information added.
