Showing Office information via Template Studio Logs
There have been updates to both Template Studio and the Excel Extension which will allow for the displaying of the new logos and the new office fields.
There is a new library item called Project/Office Logo in Template Studio. If this item is added in a merged cell of the header or footer it will display either the Office Logo or Project Logo depending on user Selection.
Once the library item is added the properties window has a mode selection with three options:
Note: The original Logo library item has now been renamed to Static Image. This item is needed if Images stored in the Template Images dialog within HBSI are required.
The Data Label Text library item has also been expanded to include the addition of the new Office group. When added to a merged cell in header or footer, data from the Office grid can be added to the Template.
Once saved the log can be previewed in Template Studio and will show in HBSI when a Quick Log is run using the new Template.
