Linking Offices to Projects
Once the offices are set up they can now be linked to the projects. Offices can be linked on project creation and also after a project has been created via editing the project.
When the Edit Project dialog is open, the Office field is displayed now as a drop-down list which will contain the Offices stored in the Office grid. Select the Office to be linked to the project and press Save to apply the changes.
There is also another Logo tab which allows the addition of a Project specific Logo. This may be useful if the project being worked on has other parties involved, if that is the case a separate logo can be added here.
