The different types of data are listed and explained below. If a different data type is selected the further options may become available allowing for further definition.
- Boolean – Allows for a True or a False value to be selected.
- DateTime – Allows for a date and time to be selected using the DateTime picker.
- Decimal – Allows for a numeric value to entered to a certain precision.
- Integer – Allows for a full number to be entered with no decimals.
- String – Allows for any information to be entered.
- Picklist – Allows for a user to select an item from a list.
