Import and Export Mapping
After a data field has been added to the system, it will then need to have the source data defined to allow for data to be imported into it. This will need to be done for both tables and fields.
To add the import definition to the table, select the Model Structure option from within the Configuration section of the Ribbon and then select the new table, followed by the Edit Mapping Button.
The AGS type will then need to be selected from the drop-down followed by entering the source group which is the name of the AGS table that the data resides within.
Any fields will then need to have their mapping defined. To do this select the new table and select the option for Edit. On the Edit Group window select the required field and then select the option for Edit Mapping.
The Edit Import Mapping window will then appear allowing for the AGS type will then need to be selected from the drop-down. The Source group is the name of the AGS table that the data resides within. The Source Column is the name for the header within the AGS format.
